Battery icon, 3g and signal icon gone Help!!!!
youch88
13
I installed the No Battery Percentages zip file to my fascinate, and when i boot my phone phone the battery icon the 3g/1x icon nor the signal bar shows up on the statusbur. is there anyway to fix this?!?!
I'm running comm rom 1.3 btw
...then be sure to reboot. It may take a few reboots to get what you want to show up...
I've tried this and rebooted about 10 times now and still nothing :-(......I feel that i may have to flash back to stock and then we-work my way up to comm rom. any other ideas guys?
As I always say, it's good to have a backup in CWM to restore should something like this happen. I like to make one every couple of days.
With that said, the easiest fix is to flash a theme that has the framework themed. I like Nitro Honeycomb. That should bring you back.
If that doesn't work you may try reflashing KB1.3 or just wait for 2.0 to come out (which should be soon).
Reactions: youch88
I actually thought of reflashing KB 1.3 before u posted this and it seemed to fix the problem...thanks anyway guys :-)
