Battery Indicator Freezes/Stops Reading
AirlinerDudeB6
Active member
Feb 15, 2011
41
3
Ok, so I have had my Thunderbolt since launch day and have had zero issues. (knock on wood)
Yesterday both the battery indicator at the top, as well as the HTC Widget stoped responding when it hit 30%. I did a restart and it read 19%.
I do understand that a resart drains some battery life (5%-8%) so that is not my question.
After I charged it back to 50%, later in the evening it again froze at 30%. After a restart it again read 19%.
I have also done a battery pull thinking this would clear anything that was causing it to give a faulty reading.
Has this happened to anyone else?
Anyone have any thoughts? Do I have a faulty battery?
Go into Settings > Power > under Power saver, what is "Turn power saver on at" set to??? My guess is it is 30%.
Mine seems to have frozen at 100% a couple of times. I figured maybe it was the calibration being screwed up because I have a 2750 and two 1400 mAh batteries.
leehrenterprises
