Battery Issue*** Please help
sandoff
208
10
So my awake and up time are both the same, and have been through multiple resets and battery pulls. Im not sure if this is an app or what but lately i havent made it more than 4 or 5 hours period without my phone on a charger
Have you bump charged the device?
Have you checked your battery usage in the settings menu? (I think that's where it is?)
Are you using your phone a lot? (screen brightness, 4g data etc.)
Download spare parts and see what is eating up partial wake usage. Also look at your battery usage under about phone.
Do you have beautiful widgets installed or any other widget apps? Do you use City ID?
Also, you can try spare parts to check partial-wake usage.
edit:// What that ^^^ guy said.
im in and out of a 4g area, i know that has a big affect, but I took the phone off the charger (bumped) at 10 and it was at 36% before 1:30 today and ive been at work sparingly using it, asleep more than 75% of the time.
Battery Usage:
Voice Calls 57%
Display 25%
Android Sys 4%
cell standby 4%
Shazam 4%
phone idle 4%
com.htc.launcher 2%
Im in the middle of installing a rom, wiping and reseting everything.
None of that really accounts for why your awake time is the same as the up time. Is that problem still persisting?
The new Rom fixed it, they differ by about 25min now....p.s. before my refresh icon looked frozen in the notifications bar, but nothing was refreshing?
If by "refresh icon looked frozen" you mean your Sync icon was permanently syncing, it may have been because you configured for ActiveSync and for "frequency" you selected "PUSH". Not sure why that happens, except that true Microsoft Activesync does not have a "PUSH" mode (by that name). That happened to me when I selected PUSH within ActivSync. Instead, I changed it to 30 minutes and all was well. And... I still got my mail virtually instantaneously (5-90 seconds).
-Frank
Does anyone know if spare parts uses up a good portion of battery? I've been using it and I dont see a need for it anymore, and if it uses up some battery (even when not using the phone) then I'm just going to uninstall. However, if it uses minimal battery then I just figure I would leave it.
unreadydrake
