Hello,
I've just got my Axon 7 last Thursday. I had before a One+One and I was pretty happy with it, but I'm a geek so when I saw the Axon, well...
So on Thursday, when I first started the Axon and got the message "Do you want to reinstall your apps"? I said Yes and all the Apps I had on the OnePlus got installed on the Axon right away. Mistake?
During that first installation, the battery of the Axon went down like crazy. From a 100% (I had slow charged it the night before), it went to 5% in 3 or 4 hours. Got quite hot too. So I figured: "lots of work, let's see later" I charged it with the charger right after, fully.
The next day was fine. But I'm not a player, my main uses are the social apps (Facebook, Twitter), some text messages, one phone call that lasted 15 mins, web browsing, and some pictures (like 10) at night without flash. Got home last night with 10% left. Figured it was ok. So I charged it fully again.
This morning, waking up, the battery is at 80%. I haven't touched the phone... GSam says that Mobile Radio used 48% and the screen 34%. I activated the WiFi when I woke up and GSam says 18%.
I didn't have that "issue" with my OnePlus so...
My mobile network uses 4G but with my OnePlus, inside my home, I would only have something like H+ or rarely 3G.Maybe the mobile network is draining the battery. Since I haven't rooted the Axon (is it possible? I'm not too found of that), I can't used apps like WakeLock to see if something else is draining the battery...
I have installed of course the latest update from ZTE.
What do you think? Should I do a factory reset and restart from scratch, not reinstalling automatically the apps? Those are pretty basic apps btw, like I said no games, nothing fancy...
Or... do I have a faulty battery?
I chose this phone over the OnePlusThree because of its battery, I would be quite pissed if I had the only Axon with a defective battery
Thanx for your help and comments
