battery level not changing
zachnelson
150
7
Hello. I've been using battery graph to measure my battery level but recently my battery level stays on a straight line until I reboot and then it moves down 5% and starts another straight line. I've pulled the battery, factory reset the phone and cleared the data and cache of the app. Help?
How long does it stay on a straight line for? How long do you watch it, does it move while its charging?
it moves up when it charges.
the longest ive had in a straight line was... 20 minutes?
and that was when i was actively using the phone, i checked it at 1 point, and then used the phone, pandora, whatever and 20 minutes later it said it was the same
bump? sorry still having this issue. its really annoying because my phone just suddenly turned off when i thought i had 50% battery and i thought something was broken.
I'm having the same issue after switching to the extended battery. It never drops from 100% until I reboot. Will this fix itself or do I need to do something? Is there something wrong with the battery?
I have pulled the battery several times and it isn't helping. Thanks
I tried draining it to 0% and im currently testing my second run... hour off the charger and its still at 100% so I dont think that fixed it.
Pretty annoying...
Def a firmware issue though. There is a patch due out this month to fix some of the issues.
wanamartah
