Battery life at my work question
NHBass39
840
7
Ok so I work in a steel building and get so so data it's in and out. My battery life really drains when I'm there. Any ideas on how to combat this? When I'm out and about my battery is awesome, but its just at work where I'm killing it.
If you can connect to wifi it should help out tremendously. Otherwise its pretty difficult if not impossible to improve your signal. I would turn off mobile data when you are not using it. Not the best fix but would help battery life.
What's your opinion of the app TASKER?
Gordo52
