In theory ART is faster and extends battery life because the apps are pre-compiled. With Davlik apps are compiled on the fly when you launch them. This increases speed when opening and also cuts down on processor load which should increase battery life. How much depends on the app involved, but I have noticed a slight increase in battery life as well as app start up. The downside is pre-compiling the apps take a little bit more drive space, though not much more.
Yes, rooting has nothing to do with it.
ART uses the cpu far less than dalvik in everyday use that extends the battery. Dalvik has to covert portable bytecode into executable code for the specific CPU in your phone every time you start up an App. ART converts all the Apps bytecode into executable code for the specific CPU in your phone just one time and stored it that way as a App ready to run in the CPU. So your App will never have to ever take that extra CPU step ever again under ART.
I have just switched to ART. I'm gonna observe for a few weeks and see if there's a drastic change in battery life and performance. The things I've noticed, though, are less RAM and 0.6 GB added to my storage.
Sent from my Nokia Lumia 1520 (RM-937 Malaysia) using Tapatalk
ART does take a bit more storage, but I'm happy to spare the room on my 32 GB N5 for the performance and battery life improvement it delivers.
Sent from my Nexus 5 using Tapatalk
Same here man. I don't feel compromised having less storage since I'm not a storage junkie like others. I still have 10.3 GB free. ^_^
Sent from my Nexus 7 using Tapatalk
Is that all, I have 24Gb free and nothing to fill it with...
I'm also interested to know about optimized dalvik. I'm on stock unrooted and I switched to ART last night. No improvement in battery that I've noticed so far. My battery has been fine though, just not as good since I filled up most of the phone's internal storage (temporarily).
Sent from my LG-LG870 using Tapatalk 2
