Battery Life - Is mine normal?
Juriaan727
15
Hey all,
This is my first day with my note 4 and I was wondering if my battery stats are standard or if something is wrong. I did have my screen brightness on pretty strong (screen takes up 63%).
The phome went off the charger at 7 am and ita now 12 pm and my battery is at 25%. I do use my phone a lot ( the screen on time at the moment is 3h 22 mins). I do game a lot (about 1hr of the ost is gaming).
Any ideas guys? I will try and attach a screenshot of the battery.
Thank you in advance!
Unfortunately this is normal and if youve been gaming for an hour on high brightness then you've done quite well. The note 4 has a qhd screen remember which is a huge power hog on high brightness.
The higher you go on screen brightness, the faster your battery drain.
Your performance looks pretty normal for the use you describe.
Agreed. Normal for the usage described.
Sent from my Verizon Samsung Galaxy Note 4
cinemacritic
