Battery life? not great?
bigsmoke79
243
I've just watched a YouTube reviewer's 1 week with the Note Ultra and without saying too much (cause they can't until the review embargo is lifted) I get the feeling the battery life on this especially the Exynos version isn't gonna be great!
Anyone read or seen anything similar? its something I need to know as I'm moving from the S20 Ultra
Honestly it’s important to not take too much from these as they are review units and everybody usage is different
My advice is try it for yourself and return it after 10 days if you feel it’s not good enough.
I agree
I agree but you only need to put into twitter Note 20 Ultra battery life and see, it's got a smaller battery than the S20 ultra, powering a bigger screen, and powering the s-pen.
I hope I'm wrong but I think it's gonna be a down point in all the reviews, that everything will be good but battery life is just ok.
Depends as the LTPO display is suppose to help with battery life. For me as long as it lasts me all day on normal use it’s ok but depends on how close you are to charger and if it’s needed
So there is a drain test out and looks like the Exynos 990 on the Note 20 ultra and s20+ along with iPhone 11 max, One plus 8 Pro and Xiaomi Mi10.
So the Note 20 Ultra, under intense gaming, browsing, video and camera, managed 8 hours 20 minutes, I'll let you guys take a look at the rest but being the biggest screen with 2nd smallest battery I was surprised for the Exynos chip...
https://youtu.be/TBM_40Qi-Zc
I used to worry about battery life, but no more. I use it how I want to without a care about brightness, what settings, and all that jazz. Nowadays we've got the option to have chargers in all shapes, sizes, and wattage...with or without wires. We can juice up just about anywhere in 30 min or less. I realize no one wants a device with abysmal SOT, but its just not a big a deal as it used to be to me.
Its a 10 percent difference with a more efficient screen. The battery life differential isn't going to change your life
You might be right but that's not the vibe I'm seeing online on this hands on videos, will wait on the review embargo being lifted before I jump in.
I don't plan on using the 120Hz just because I want that extra battery power.
That was a fascinating test and all done at FHD 60Hz.
True certainly with the wireless battery packs too so if you’re away from a charger this will fill a need. Not that you should need it but it’s there
We're talking about a $1300 (at least) device, even if that's now what I paid. I am NOT gimping it's abilities to save power when I've got more power readily accessible. May not work for all, but...
Didn’t say you should but options are there for charging if it’s needed. For most people this will still last most of not all day. Everybody has different usages.
I play zero games so for me I’m more likely to not be as affected. Depends on your daily tasks
I'm pretty sure the N20U will get me through the day. As a back up, I have a portable power bank coming in.
