Battery life not impressive
Dominic Lynch
12
Hey so I decided that you guys helped me with my messaging problem so ill greet you guys withy BATTERY LIFE PROBLEM
So any help would be appriciated I.e your settings and proof of it working
THANKS AGAIN
It's hard to help you without knowing what's wrong. Provide us screen shots of your battery life stats and provide screen shots from GSAM, only then will we be able to help you out.
Sent from my SM-G900W8 using Tapatalk
It's really annoying is there any way to reduce the amount of battery youtube uses . I charged it to 100 percent 3 hours ago and down to 67 percent 😑
I get close to 2 days on a full charge. Screen time is generally 4 hours. I have all the things enabled that people say to disable (GPS, Sync, etc). I removed a few apps that I wouldn't use but I don't think they were anything that would drain the battery anyway. Everyone's needs and uses are different. I'm not a heavy user.
I'm heavy to rear extreme when at home which I know that it will drain battery then but when I'm in town like to town watched a half an hour video and bam 34 percent gone like WTF😣😮😡😧😢😨
Use WiFi instead of DATA for watching videos.
DATA requires the phone's transmitter/receiver to be active which requires battery power.
WiFi is very frugal of battery use.
The screen shot shows that for over 3 hours your screen was on, wake locks are solid as is Wifi. Not sure how long you were actually streaming content during that timeframe, but I think you need to use external power doing all this, if you expect to get decent battery life.
Just looking at all those active apps in your bar would answer why your battery life sucks
Reduce the amount of battery YouTube uses by not watching videos for 3 straight hours. I'm not really sure what you expected. It's unrealistic to think the phone should last all day when you have the screen on constantly.
I didn't have the device on for 3 hours straight I was in town was 3 hours and while waiting for my friend I watched a 30 min video and lost like 34 percent explain that hot shot
I say you had the screen on for 3 straight hours because that's exactly what the last screenshot you posted indicates. The blue bar under where it says "screen on" is lit up for almost the entire 3+ hours you had the phone on battery.
Post your screen on time...we can attempt to decipher it ourselves from the graph but apparently our assumptions are wrong.
Hmm u guts are actually right I'm very sorry my screen was on the whole time we'll dammit well again u guys are amazing in helping thx again
I just checked mine and I'm at about 11 hours and most of usage is from Android system. 13% of battery usage was android system. Is that normal?
DannaOgle83
