Battery Life...
sarasotatim
18
Is nothing to sneeze at :) Man I love this phone; after setting up Nova prime, at 60% after over 9 hours...surfing, txt, email, calls, playing with this thing all day...awesome!
Ive just got my note 2 and im also in love with thw battery life :-)
Sent from my GT-N7100 using Android Central Forums
awesome!! I did like the Note II when I demoed it....like it way better than the Galaxy S3.....just a tad too big though, the DNA was the perfect trade off for size :)
Its my first androd so im not sure what yours is? I came from an iphone 4s. The note 2 is big but im just about getting used to it. I love it
My battery life is terrible. Always charge all night and always on yellow by 7 pm. I'm not a heavy email user, mostly play Draw Something and add to my food diary on My Fitness Pal. And I'm on wifi all day. What can I check to make it last longer?
Sherri
Draw Something is a notorious battery hog. Probably your problem there.
I'd recommend you try GSam Battery Monitor from the app store. It doesn't save battery life, but it lets you track which apps/processes are using the battery up. You might find something that you can remedy.
vickyy
