Battery Problem
Andrey JNR
4
Plugged in the charger and all the sudden battery full 100%...
Restarted phone and it went back to normal.
Has this happened to anyone else?
Your phone is confused by how much battery you actually have. Give it a couple of full discharge and charge cycles and it should sort itself out.
Happened to me with a crap qi charger, phone went from 1% to 50% within 5 minutes apparently... Proper charge cycles with the proper charger sorted me out.
This is normal, nothing to worry about. Its something to do with the battery reading playing up. I think the phone displays battery percentage depending on the voltage readings which can confuse the phone sometimes. Normally happens when you plug the phone into charge after it has been idle for a while, if you use a different charger or if you had just been using it on your computer and then plugged it into the mains.
Yes, same thing exactly happened to my Nexus 4 recently.
