Battery problems on KK
cableghost
12
Just since I updated to KK, my battery will discharge normally until around 20%. At which point, it will suddenly drop to 8-9% and quickly lose remaining charge.
I've re-calibrated my battery. Any suggestions, or ideas as to why this may be happening?
I don't know, happens to me too. It will drop quickly once it gets under 20%.
Posted via Droid Razr M on the Android Central App
I did a factory reset last weekend and my battery life has seemed to stabilize some, but still not as good as it was with JB. And, yes the same thing happens to me, once it gets down around 20% forget it, I might as well just attach the charger because it drops like a rock after that.
Thanks @JohnS305; although still disappointed, glad to know it's not just my device.
Thanks @A895; did this happen to you in JB, or like me, only since updating to KK?
Only in KitKat. It's one of a few bugs, and the circle widget gets notifications late.
Yeah, it may just be a bug. We are still in the last month of updates so they may issue a bug fix. If not, it is time to upgrade by the fall.
Full charge when I went to bed. Screen off for 5 hours. Duploadfromtaptalk1404918123651.jpg
sent from my phone with the app
I dunno, whatever normally runs. I dont remember it ever being that bad.
Check what apps are syncing by looking at data usage in the settings and then you can stop certain apps from syncing.
NameRingtone
