Battery Question
Adam Z
78
I just got a new battery for my bolt. Should the phone be powered off when swapping batteries?
It is always best to power off the phone to allow the operating system to properly shutdown. A battery pull is typically only recommended when the normal power off procedure isn't working or there is some other problem that only a battery pull will reset/cycle the device to try to restore normal operation.
if it's not powered off when you swap the battery, it will be when the old battery comes out
sonmaria6
