Battery Replacement for 2XL
Rick Dangerous
Active member
Jun 18, 2021
26
I love my 2XL. Went with the 128GB; the only things i would change are add 3.5mm headphone jack, and microUSB storage. Other than that; perfect phone.
I'm 3 years in, and i'm trying to get 6+ years out of this phone. There is no reason for me to replace it; it does everything i want and more. It's 100% GTG, just the battery is starting to get a little weak. It doesn't last quite a full day.
How would you go about this? Local phone shop? Send it in to Google? Other Pixel specialist shop online?
Thanks!
Welcome to Android Central! I'd look for an experienced phone repair shop in your area. I'm not sure if Google replaces battery, but if they did, it would probably cost significantly more. Use Yelp or similar apps to search for a good repair shop.
Hi, welcome to AC !
Let repair shop do this , I attempted and cracked the front glass on the corners
dooleysdickulove
