Battery status pro Vs. battery indicator
scooz16
45
anyone use both?
I've been using battery widget but really would like something in the notifaction bar instead.
battery indicator seems to work well but the icon stays white and is a little blurry.
battery status pro turns green, look perfect but seems to be using a bit more battery for it to run.
thoughts??
buy the pro version of battery indicator. costs a buck, high res notification bar icon if your phone supports it, and allows custom colors for the icon
Try this. i like it.
◇BatteryTime Lite◇
by Motalen
>250,000 downloads, 10502 ratings (4.2 avg)
Free
Hammyj
