Battery stuck at 100%?
  • Thread starter Thread starter Thromper1984
  • Start date Start date
T
Thromper1984
I have a Moto E, I charged it overnight and it has been three hours. My battery is still completely full, although it really shouldn't be. I think the indicator has a glitch of some sort. Any advice on how to fix it?
Hello.
I would stick that on Shop Android or eBay and make your fortune. :)
Try the GSam app in the meantime and see if it displays the battery percentage correctly. It also allows you to put it's own percentage indicator on the notification bar.
You could try toggling on and off the device battery indicator if it has one.
How does the Battery Usage graph look?
You can touch the graph to get more information.
kiki2025
