Battery temp and signal bar color
shugmeat
22
Hey guys, got a few questions about my nexus. First, what is the acceptable temp range (Fahrenheit) for my battery to run at? Its been floating from 90ish to 104. Second, my signal bars, what's the difference between them being gray or blue? Thanks, I know I'll have more
I'm not sure at what temp the software will go into protect mode, however, I see battery temps right around what your seeing. Right now at idle for a bit, I am seeing 87.8F so I would say your cool.
As to the grey and blue ...
Blue = Connected to Google servers ...
Grey = Not Connected to Google servers....
Ah cool. So grey is fine. Good. Now one more question. I downloaded quadrant standard to my phone and it ran about 16000. A guy came into my shop with a razr and did it and it ran like 23000. Is his that much faster?
1600 vs. 2300 ;)
Quadrant has not yet been optimized for ICS devices. Hence, the low test scores. Don't judge performance by a benchmark number alone.
That's what I though just wanted to make sure and yes it was 1600 not 16000. If it was 16000 ......
ecomranx05
