Battery Test
Just a Guy
121
5
So I had to make a trip today that was roughly 2 1/2 hours from home. When I travel I always have navigation going and am also usually streaming pandora. When I left my house my battery widget said 90% (it only shows in 10% increments). I decided to make tbe trip without use of my car charger just to see how the battery held up. During the trip I was pretty well split 50/50 between 3g and 4g service and when I arrived at my destination my battery widget showed 70% remaining. That's pretty dang good if you ask me. My old Tbolt would've probably need charged half way through the trip lol.
Pretty good... if you'd like to see a more accurate battery life than the 10% battery life ticker you might try Battery Indicator, which has a paid version called Battery Indicator Pro... my current favorite... they give 1% changes. And I think there are a couple other battery widget's that will work with Motorola device's.
Yeah, Circle Battery is a nice app. Simple, elegant, small app size, customizable, free!
Battery Circle will give you a 1% increment battery stat on your notification bar.
Circle Battery Widget will give you a 1% battery increment widget on your home screen.
khizarhayatt
