Battery Usage monitor only showing 78-81% of usage based on apps
Zman1001
225
8
Does anyone else have a problem when looking at the battery usage in settings not totaling to 100% (like all of my previous devices, and my Samsung Note 10.1). It always adds up to anywhere from 78 - 81%, b ut never 100%.
I will take some screen shots later tonight when the battery is run down more.
This happens even after a clean reset as well.
If you add all the processes that take less than 1%, it probably adds up to 100%. But this is one case where recalibration might help, because the calibration is of the file you're looking at when you're looking at that screen.
r3dpuk3
