Battery % without bringing down quick settings?
garrim85
99
9
I know the Google devs talked about not having it for battery reasons but I really do miss being able to glance up top and seeing the battery %. Any way to bring this back?
you can if you install an app, or rooted
I didn't know they don't put it for battery reason. just thought they were stumbled. like how they have to make such a big phone, or qhd screen, or take away my led. haha yes I'm bitter
Not without a new app. There's a million of em in the play store, many of them super light with no troublesome permissions. Power toggles includes it or you could just go with a single purpose battery indicator.
The same "Battery Percent for KitKat / L" app I used on my nexus 5 worked on my 6 and it shows your percentage in black text right over the stock battery icon. It's free in the play store.
This one is perfect, thanks!
how do you get it to display black text?
just realized, it's no longer white text over white, it's black over white now. just need to reset it first!
I don't feel the need to know the exact percentage; the icon is enough for me.
Having said that, I use HD Widgets for many of its features and one of them is a battery widget which shows the current percentage and, when tapped, takes you directly to the battery settings page.
Reset it first?
I meant reboot. also. if it's at 100% it won't show the percentage in number, just full battery. the percentage in number will only show if it's at 99% or lower.
I included a screen shot to show you.
kankuraon
