Battery won't fully charge
pegleg#AC
Active member
Apr 29, 2010
28
In the last few days I noticed that I can't get the charging level above 96%. There doesn't seem to be any discharge problems, and I'm still getting the same usage from the battery. Right now it doesn't present any problems, but I'm worried something is going on. Any ideas?
Yep, and I'm using the factory charger. It works, it just never charges past 96%.
Charger must be getting weak..... Motorola Razr Maxx HD charger took it right to 100%. Funny problem though, the Asus charger would go to mid 90's in the normal amount of time.
Why worry about not being able together over 95%.
May be that the battery calibration is just a little off.
