battery
yopej14
Hello peepz...can someone please tell me if your htc chacha gets hots easily..even if im not charging its gets hot easily specialy if i using the wispot..
That's normal. If you're making the device's CPU make lots of cycles, then of course the device will generate some heat. The WiFi Hotspot feature is CPU - and battery-extensive.
Sent from my HTC Sensation XE with Beats Audio Z715e using Tapatalk
kolelno1
