BB Priv Double Tap Screen Not Working
mrdugan2123
Hey fellow Priv users. Kind of a weird situation, and can't find anything reported as of yet. But is anyone else having issues with the Double Tap to turn on the Screen? It worked flawlessly since day one, but suddenly is not functioning. It started before the Marshmallow update, Yes I have tried turning the Phone and Feature off and on. I cannot figure this out. Any suggestions or people experiencing the same thing?
Did you do a hard reset? Hold power button for 35 sec it will vibrant a few times then release. May work for you. A reset usually fixes problems like that
You found the option and tried turning it off and on?
I will second the advise to reset the phone. There are several different levels of reset depending on how long you hold the power key down. I think the most serious of them is at 31 seconds or thereabouts.
If that doesn't work, you can try a factory reset My phone had a lot of weird glitchy behavior that all went away when I did a factory reset, for what it is worth. . That will wipe everything off your phone, of course, and is a nuisance. But if you have stored your contacts and whatnot with Google, it's not nearly as bad as in the old days. And I was pleasantly surprised to find that the SD card (under Lollipop, but probably still true under Marshmallow if you have it set up as external memory) wasn't affected, so I didn't have to re-copy my photos and music to the phone. Mostly I just had to restore what apps I put where on the home screen.
Yeah. I've actually reset it completely. Everything is linked thru Google, so I don't mind doing it from time to time. But still not working :-(
Ariwenni15
