Beautiful Widgets Home problems
Couple of problems I noticed after I installed the update and created a new home widget:
2. And this is a deal breaker for me. I don't see a way to specify what weather app I want to open like I could previously. I don't like or use Accuweather. They don't report the dew point temperature. Dew point is the main thing used in Phoenix as a measure of summer humidity/comfort. Instead they use something called RealFeel?. What the heck is that?
I guess for now I'll stick with my ugly combination of clock and Weather Channel widgets.
I was able to set the weather channel for the app it open when tapping on the 5-day forecast. Is that what you mean??
Thanks for the update. Beautiful Widgets became my first paid app because I was so tiered of Google weather being wrong. Now I just have one stupid question to ask you that have used it before. Is there anyway to change the setting on it without removing it and creating a new widget?
Also is there any skin out there or setting that makes it look closer to HTC Sense UI? Some are close but they still clash with Calander widget that I'm using, Smooth Widget.
Yes that's what I mean. Under Configuration > Advanced I see a Time Application and Date Application for selecting those apps but don't see something like a Weather Application. How did you do it?
go into config settings, scroll down to advanced, select forecast application, it will load a list of apps, then select the one you would like. Then after you save the settings you have to tap the weather icon from the home, then tap on the 5 day forecast.
I believe it was like that before.
I don't have a Force Application choice. Only Date and Time choices. This on a stock Droid 2.1.
Strange, I have a droid incredible (2.1 stock)
the option should be right with the other 2 under advanced. Maybe try a reboot or reinstall.
Several hours after the update, and with a new widget installed, I still don't see any change in the temperature, even when I select the Accuweather.com five day display. I can browse to Accuweather.com, and it shows the local temperature correctly.
Well what do you know? I just another BW widget with a Weather Application option. I'm now a happy camper. :D
Now I'm not a happy camper.
Five hours ago I installed 3.01, with a 30 minute update time, gelocation on and GPS off, and determined that it seemed to be working. Now that I've been home for several hours I look at BW and see that it has updated my location but the temperature is at least 2 hours old. Accuweather website, Weather Channel and Weather Bug all show a temperature 20 degrees lower than BW. Deleting and re-adding gets the widget working again. Who knows for how long?
I was faked out the same way, I think. I'm pretty sure the minimum interval set up in the Widget for updating the Temp is every 2 hours, so that it isn't really tightly in sync with the Accuweather web site, or other more immediate sources. I don't know why that interval couldn't be shorter. How much battery power would it take up to retrieve the temp more frequenty?
Yeah I noticed that too but I changed it from 2 hours to 30 minutes so I know that wasn't the problem.
BW 3.0 is what it should have been all along. Google's servers are *** and were starting to make people hate the app. I updated and it's been on point every since. No issues at all.
Re: Beautiful Widgets diplaying high temp
Finally! Changed weather server (to accuweather). Works so much better now and I switched back.
Sent from my Droid using Tapatalk
I hadn't occurred to me to scroll "UP" from the default 2 hour setting at the top of the display. I thought that was the most frequent choice allowed. I just went back and reloaded mine to the 30 minute interval.
I wish there was an easier way to update the settings on widgets, though, rather than removing and reloading the widget, then having to restore all of the settings all every time a change is wanted.
Thanks for that to, Evil Monkey. It works!! I'm on the road now, but I'll be sure to give you an official Thanks when I get home.
Sent from my DROIDX using Tapatalk
This is not my week. Today the 3.01 version is telling me it's 78 degrees and sunny. Goto the Accuweather website and it's 78 degrees and showers. The sun hasn't been out all day. BW also tells me the high so far today is 95 but it hasn't been out of the 70s since the rain last night.
And I can't download the 3.02 version since the market gets stuck on authorizing purchase.
Very frustrating.
Very frustrating.
Tried deleting the widget and re applying it?
Are you using Geolocations?
If so try this Settings>Location> Uncheck the Location settings and recheck them.
I should have left well enough alone. I decided to be a good citizen, and update my Beautiful Home Widget to the most current version, to 3.02. With the new widget, tapping on the 5 day Accuweather display just drops the DX back to the home screen. I see others complaining about this and other problems on the Beautiful Widgets page on Appbrain.
I had some issues after going 3.02, but now they're resolved. What I recommend everyone with issues to do is to completely uninstall Beautiful Widgets (not just remove from home screen, but completely uninstall). Then reinstall from the Market and try again.
Completely resolved all my issues.
reblkari666
