Been using same battery since June 2013
aflacks
Active member
Aug 12, 2013
29
In my S4 Active. Lot of charges, and am wondering when does the battery begin to lose its capacity? I am noticing it is taking a bit more time to charge up. (using oem charging devices)
Should I just give it a fond send off and buy a new oem battery?
Thanks in advance.
I understand that if you care for a battery, it can last for many years. It may be worth taking a look at it....if it's swollen and can be spun on a flat surface, it's bad, and in danger of eventually bursting. Even if undistorted in shape though, it could be going bad.
