Behold, the best Screen protector for the Note 20 Ultra.
Aaah. At least not a real hole. But like I said, doesn't seem necessary.
Well, I can only imagine that if it wasn't there, the fingerprint reader would probably not work at all. It was ugly, stupid and I keep thinking that I should burn the store down so no one else would have to deal with it. :D
And, if I'm not mistaken, did they paint the chin of the glass black?? :-\
Yeah that's the problem with these glass screen where they are only glued at the edges. as form fitting as it looks against the original glass, there is going to be some micron of space thats going to keep it from being consistently accurate. I guess they thought thinning it out was the issue. At least that's my theory.
iPhone glass screens... adhesive on the entire side and never ever have a problem with responsiveness with those. I'm sure if they had a FPS would be no problem with adhesive created a constant and tight seal between the two glass pieces.
Why on earth would you get anything with an eyesore (fingerprint circle) in the middle of the screen?
This screen protector is so good I wanted to warn everyone about it.
I bought this from tmobile and I was desperate for a protector because I thought one would come pre-installed.
This bad boy diminishes the clarity a bit of the screen. No need to see that beautiful screen
- The fingerprint area is thinned out as you can see from the picture
- The selfie camera is covered
- All this for $45
Is that the pure gear? I had the pure gear. Wasted $45. FPS wouldn’t work and orange peel bad. They wouldn’t return it either.
I am still in awe at how a company thought this was ok to release.
You assume that T-Mobile actually LOOKED at these. They probably saw the spec sheet and someone said OKAY without any real testing. They had these for the Note 20 and Note 20 Ultra in stock the day Pre-Orders went live.
Hell, my Tech 21 case I bought from them was on the wall before they even knew pre-orders went live!
- All this for $45
LOL! I like the sarcasm:)
I personally like the zagg ultra clear. I know it's not glass but I used it on my S20 Ultra and it kept it looking brand new. I tried the glass fusion on the note 20 and I screwed up the install and had so many bubbles I couldn't stand it. My fault not the screen protectors.
sshkjgh7788
