Best and worst Clear Case?
Curious for the Obliq naked clear
1) if the kickstand is such that the Volume or Power button is up (is kickstand reversible)?
2) if generally sleek or bulky
3) if comfortable to hold, Or soft or leather shell better
4) if screen protector would be compatible - which specific screen protector do you recommend with it?
5) if it would fit slide into a belt holster
1. Volume button down. Not reversible that I can see
2. Cross between sleek & bulky
3. Not leather but comfortable to hold IMO
4. I'm currently looking into compatible screen protectors
5. Haven't tried sliding into holster but kickstand serves as nice clip-on for waistband
^ the technical customer support obliq person said reversible.
Look at the third photo in your link.
What color edge did you get?
Don't know if this was addressed to me or not?
I'll have to double-check on reversibility.
I got full clear for my gold casing.
I'm curious about that 3rd photo in link and kickstand reversibility?
How is the amount of front lip (~1.5mm) protecting the front screen - seems modest protection at gain of slim design?
Those are not my pictures so I can't speak directly to them.
The wraparound at the lip is sufficient. There may very well be others that wrap around more but as far as I'm concerned, that takes away from styling of the phone.
This is my weekend case.
Spigen Ultra Hybrid Galaxy S7 Edge Case with Air Cushion Technology and Hybrid Drop Protection for Samsung Galaxy S7 Edge 2016 - Crystal Clear
https://www.amazon.com/dp/B01A7IDKM...ag=hawk-future-20&ascsubtag=UUacUvbUpU5639581
Funny, I use it as my work case and a black Vena armor case for weekends. I guess it depends on your job activity vs recreation activity. Also, just grabbed a tech21 Frame. Very slim w impressive protection but a little slick (so the "protection" part may get a run for its money)
iwansandi19
