Best Android Keyboard?
I use Swiftkey as well. A couple days ago I installed the Blackberry keyboard just for the heck of it. I liked the swiping up on the word predictions but it doesn't have swipe. It also doesn't have any customization capabilities so I deleted it and am sticking to Swiftkey.
Where did you get the blackberry keyboard?
Minuum keyboard with sloppy typing.
I used to be a Swype keyboard person, but I went back to tap typing with Minuum. That sloppy typing feature is awesome
Stock keyboard for me. I have tried about every keyboard on the Play Store and keep going back to stock because it works for me. I would have stayed with Google keyboard however if they added a dedicated number row. I don't understand why they don't. That's another key reason why I'm not switching to iPhone. Why have such a huge screen if my it's not used efficiently with a dedicated number row.
I've been using SwiftKey since 2011 and it keeps getting better.
I like the numbers on the keyboard so I use Sammy. I just wish they added secondary characters to the top row of numbers to get brackets and other symbols on the main keyboard.
I like the Samsung keyboard too but the SwiftKey has option to add number row
Does it have the % symbol on the main keyboard? It is a symbol I use constantly
That is possible if you choose show number row in all layouts.
Maybe I will try it. I have it on my phone but there is something I did not like so I switched to Sammy. Don't remember what bothered me.
On Google keyboard if you hold down the period you can swipe up to % fairly quickly
You can also add the number row to the SwiftKey keyboard.
Posted from my Galaxy Note 5
paradigm76
