Best Case for Incredible
Thanks for taking the time to write this up! Appreciate the pics too!! I will check my local Best Buy and see if they have any in stock as this is pretty close to what I was looking for. I also searched Google for iphone pouches since they are very close in size and found these two in case anyone else is looking for pouches:
Apple iPhone Genuine Leather Vertical Pouch (Black) - WE20404LC0APLIPHN-03 - Buy.com
Suede Pouch for Apple 3G iPhone, Black by Eforcity - CAPPIPHOLC14 - Buy.com
I think I'm going to order the 2nd one as well and see how that works out.. I will report back when/if I do.
Received my pocket pouch today... I ended up going with this one (2nd link above)
I'd say, for $7.47 it was worth it. It does fit in there pretty good with the VZW black silicone case on the Incredible as well. The very tip top (like 1/16") sticks out but that's it. It will serve its purpose, that's for sure..
All in all I'm satisfied!
rew001 said:
Any news as to when the extended battery (3500mAh) and door are available?
Thanks!
We don't have a time frame as of now, but we will definitely keep everyone updated!
I ordered 2 Seido ... Ash Grey and the saphire Blue...
Figured I would grab them cause they are gonna be gone fast I think...
For the time being I picked up one of the G1 cases from amazon for like 6 bucks and its perfect
It's been rough finding a case I'm totally happy with. The last case I used was a Incipio case for the Storm and it was perfect. A low profile case that didn't add much bulk. The Seidio case looks like it fits the bill, but I'm a bit unsure about the two piece design.
The two-piece case for the Storm was a problem. The little tabs would eventually break off and then it wouldn't lock. This, apparently, (unless I'm misreading) involves two pieces that slide together and eliminate the tiny clips that break. If so (and someone correct me if I'm wrong), this should be a very nice case.
BTW...I agree. The Incipio Feather was a very nice case for the Storm. Not a lot of protection though as it is very slim. Still, I really liked that case as it performed well and kept the Storm's profile. Looking forward to them coming out with something similar for the Inc.
I used a leather side pouch from Smart Phone Experts for my curve, will prob go with something similar for my DI.
+1. At least it will do until Incipio comes out with a case for the Inc.
Incipio would be a nice case, if they could get a feather version, single piece, out that would snap onto the DI. It would then be a must buy. However Seidio has the InnoII Case coming that should be nice even though I have a few concerns.
I had this case and because of the battery pulls, I soon destroyed the little tabs and the case became unuseable...
I also had the Feather Lite case also... but it broke also after the constant battery yanks ...
Both were for the Storm 1...
Lego
Lego
Good thing you don't have to do battery pulls with the DI!
I have both the red Verizon silicone and the Sena black pouch made for the Inc. I highly recommend both. I'm very impressed with the fit of the Sena. Slips easily in and out of my pocket and fits the phone perfectly.
Will the Incredible fit into the Sena black pouch with the Verizon silicone case on it? Also, can you provide a link to the Sena black pouch you have?
TIA
InKatysOpinion
