Best cases for Samsung Galaxy S10
Their customer service is also non existent. If you email or try to contact them you will never get a response.
Yep, I actually tried to contact them by email a couple times now with no response. I'll be very disappointed if I can't get a hold of one of these. Seems like they'd wanna make more of a hot item.
Wonder if they have been bought out by Zagg? I clicked the contact link and was taken to the Zagg website.
I went with 2, so far that I haven't used before and are a bit different.
Haven't gotten this one yet but a bit concerned it might be too thin and flexible.
https://www.amazon.com/dp/B07MMQPGRN/ref=cm_sw_r_cp_apa_i_Km9KCbJ17039P
This one seems like a solid case, back is nice and is very comfortable to hold. One down side is it might be too hard of TPU. Would have liked it to be a bit more soft in the corners.
https://www.amazon.com/dp/B07N7V4H6...ag=hawk-future-20&ascsubtag=UUacUvbUpU6509020
Galaxy S10 Plus case, Bosunny Samsu...07MMQPGRN/ref=cm_sw_r_cp_apa_i_Km9KCbJ17039P
QITAYO case for Samsung Galaxy S10 ...07N7V4H66/ref=cm_sw_r_cp_apa_i_Jp9KCbZA5SXYA
Linky no worky !
Love the looks of the Monarch. Had one for my S8+. I think it takes away from the sleek look of the phone though. Picked up the Spigen Tough Armor and Air. Been using the Air mostly for the S8+.
They're $15 at Walmart. I had the black one and liked it, but returned to keep the Ringke Fusion X since that one has clicky buttons which won me over. Can't go bad with the Incipio though!
I'm using the black one, also from Walmart, on this ceramic white. It's a nice case for an almost Amazon-like price.
https://www.amazon.com/dp/B07MMQPGRN..._Km9KCbJ17039P
https://www.amazon.com/dp/B07N7V4H66...cUvbUpU6509020
Both of these cases are great. I have the second case and it is perfect for me.
Here is the Caseology Parallax for Galaxy S10 Plus Case (2019).
The fit is superb, and the way it feels in your hand. Solid, great texture. Doesn't grab particles like some other cases I have had. The buttons all give a positive feedback. Plenty of room for the connections on the bottom. There is enough lip to protect the screen. It is also a very light case.
This is my favorite case and will be my daily for now.
sshkjgh7788
