Best icon pack
What nova setting allows you to use different icons in the app drawer versus the homescreens?
First you apply a whole icon pack from Nova and then you edit your home screen icons one by one. This way the drawer will keep the original icon set. In your home screens you can mix as many different icon sets so you want.
LOL it's not a setting brother. Use your main icon pack. Then on the homepage just hold icon until you get the small menu; select "edit" then click the icon. You should now see menus which include a list of any icon packs you have installed. Then just select your choice of icon for that particular app and repeat for each app on your homepage.
Posted from my AT&T Samsung Galaxy S6
i could be wrong but i think he is asking how do you change them in the app folder, not when they are on the desktop...
Same here, I keep my list down by skipping many that haven't been updated in the last few months.
I've kind been doing the same. Colorful Metal hasn't been updated in a while but Vivid is basically the same idea from the same developer.
You can either change them individually by dragging them to Edit or in Nova settings go to Look and Feel and pick to change the entire set.
Nova Prime launcher. Material Dark theme. Iride icon pack
I like Balx icon pack
Sent from my Galaxy S6
I use the Moonshine pack too, although I would not say it is a dark icon pack. I think it is the closest icon pack to the Material Design icon pack from the theme store.
Give Glim a try.
Using all green Phix icons for now
Cobalt icon pack.
Spatial Glass icon pack. Needs more themed icons.
Ovo icon pack.
Velur icon pack.
Stealth icon pack. Probably needs a black wallpaper.
Ashok Dharshan
