best keyboard for the note 4....??!
Slightly off-topic but does anyone know how to change, or if it's indeed possible to change a word so that it starts with a capital letter after it has been typed on the stock Note 4 keyboard?
It's possible to do it on SwiftKey but I can't seem to do it on stock.
Just to make it clear, say for example I type a name or another proper noun that the keypad doesn't recognise, I either have to delete and restart with a captial or change the first letter to a capital. On SwiftKey, I can just tap the shift key whilst the word is highlighted and it gives me the capitalized version on the correction list. Can this be done on stock please?
Samsung/Stock.
I love the "My Hot Keys" feature, so much easier entering eMail, Passwords, etc.
Try typing the word then before hitting space hitting shift. see if it gives you a capital option.
Using Google keyboard for a long time now and it's predictability has got so spit on for me.
I can slop slide with minimal errors.
I'd recommend SwiftKey. Lots of different themes and kind of reminds me of the blackberry z10 keyboard.
On note 3 I used all blacks mod which made everything dark theme.
The keyboard there was the best non BlackBerry keyboard I've used.
I'm totally digging this google keyboard! Ain't going back to stock😀
I was a long time user of swiftkey then I try TouchPal and like it much better to me I think it predicts much better
I finally got fed up with SwiftKey's poor accuracy and much-diminished prediction ability and tried Swype again.
They definitely fixed the problems. Accuracy is superb, it's very responsive, and I find the prediction slightly better than SwiftKey.
I just wish Swype had options for dedicated number row and the cursor errors.
I prefer the SwiftKey layout, but Swype just works a whole lot better for me.
Im another fan of TouchPal... used it on my G5 and use it now. To me it's the best one I've used.
There's a reason for that :). The BB10 keyboard is powered by SwiftKey.
I was a huge fan of the z10 keyboard, but I do not really like swifkey! I prefer Google's lollipop keyboard! Looks clean and the prediction is very good!
Samsung keyboard suck keep hiting the number. Thank you google keyboard.
I've found having a dedicated number row is my #2 priority (swiping is #1). So those without that function are of my list.
Every time I read about keyboards so many love swift key, so I try it out again. The thing I don't like about swift key compared to stock (which is what I use), is when you misspell or the keyboard picks the wrong word, stock allows you to delete the word with a single backspace instead of backspace each letter. I also find stock easier to select a close word when it picks the wrong one. If swift key could mimic these 2 things (I don't see it as a setting), I'd try switching.
I've Swype, swift and Google keyboards installed on my phone but I've been using the Google keyboard like 95% off the time. I find it much more useful for the kind of broken/slang English I speak with my families and friends. Swift key may be accurate but it brings up so many error for me.
Sent from my SM-N910C using Tapatalk
Ariyanto darmana
