Best Moto X Cases
My biggest problem is that I want a waterproof case really bad. But there is none readily available to buy :'(
I hope this isn't a re-post. I searched the thread first. Incipio is releasing a waterproof case for the moto x similar to lifeproof. I can't wait to check this out.
Incipio® Announces Extensive ATLAS™ Ultra Protective Waterproof Case Offering with ATLAS® for Latest Motorola and Amazon Kindle Devices
I'll believe it when they actually hit store's. That would be the same Incipio that announced a battery case in August and never delivered.
I picked up "Hyperion TPU" off Amazon for about $6. Pretty cheap case that came with a screen protector which is cheap as well :O It does make the buttons a little harder to operate but I don't use the unlock button very often with the X.
I like the way the shape of the X hides the bulk of the phone even with a cheap-O case!
I too got the Black Hyperion TPU case for my Moto x (Royal Blue). The case is of real good quality. It has nice matte finish at the back and good grip as well. The free screen protector is of decent quality too.
But, the black colour case does not go well with the Blue Moto X. In my case, with the cover on, entire phone is black and the dimple shows Royal Blue which is kind of ugly.
Now, I am using my Cimo Blue case which is a perfect fit. The colour of the case matches it nicely. 10/10.
I have the Hyperion tpu case but found that dust particles would get inside and scratch up the piano black front and side edges. In now using the bear motion quicksand case, which has become my daily driver. I also have the seidio surface hard case but prefer the quicksand case.
Sent from my XT1053 using AC Forums mobile app
I think that will happen with any TPU case. Taking the phone in and out of your pocket is going to force some particles under the case edges over time and that's what happens. Not sure how you get around that with any tight fitting case.
That's true. I never noticed this issue until I saw my wife's N4 have it with her Cruzerlite cases. They left small marks all over the metal trim. I just never thought it was going to be that noticeable on the Moto X but I can live with it.
We need more premium cases for the Moto X dammit!
Sent from my XT1060 using Mobile Nations mobile app
I'd go with the Seidio case and holster combo. I have it and the Otterbox Defender and though it's easier to insert and remove it seems more secure and less apt to come out on its own.
I agree. In the course of 1 year the retaining clip on my Otterbox (Galaxy Nexus) broke 3 times - leading to as many drops from 6-8'. My only disappointment with the Seidio holster is that it doesn't have a lock on the spring clip that they used to have on holsters for older devices. I can't see how this improves the quality or usability of the holster, so I assume it was removed for economic reasons.
Sent from my Moto X using TapaTalk
This is a disappointment. I bought the "Diztronic High Gloss Clear" case and it came being opaque instead of transparent.
Realize this MIGHT be a tad expensive but I'm liking this belt case. http://tuff-as-nuts.com/Motorola-Moto-X-Belt-Case.aspx
I had one of these for my Note 3 and it was excellent quality and build. Real leather. Company is based in New Zealand. I might try and see if my old one will be compatible size wise with the Moto X. If not I'll buy another one. I know size wise there is a difference but depending on the fit I may just use the one I have
I wanted a case that could take a fall, and enough grip that it wouldn't easily fall out of a shirt pocket. The abuse resistance I needed for a teen daughter that has broken every device shes been given. I ordered 1 Trident Cyclops to try out and see if the wife and daughter liked it. Both approved, and I believe this thing can take a drop from any reasonable height and survive after it stops bouncing. A big plus was it doesn't massively bulk up the phone like the Otterbox's tend to do. Very happy with it after I ripped out the built in screen protectors.
Amazon.com: Trident Case CY-MOT-X-BK Cyclops Series Case for Motorola X - Retail Packaging - Black: Cell Phones & Accessories
I'm really happy with the Otterbox commuter case I bought. It didn't make it as bulky as I thought it would. Seems pretty solid.
I'm considering this one: Nokia Lumia 920 - UltraSlim
An early post mentioned the size was similar to the X, just slightly wider. For $23 I might give it a try as I really am not wanting to put a regular case on it and ruin the feel of the phone. Still undecided at this moment.
I have this. The case is slightly wider than the device, so it's not a snug fit. But I've come to like the fact that the phone slides out easily when I want to remove it, and the case is nicely crafted leather which looks great and does exactly what I want it to do -- protect the device from damage in my pocket.
You found any wool felt ones? Those scream premium plus I just ordered a wool felt laptop sleeve.
gulkhile
