Hi, if you look on Amazon they have good ones at great price. I dont have any to recommend , maybe some other members can chime in .What's the best phone holder via windshield or vent mount that has fast charging capabilities that's good quality for a decent price.
I love my iOttie. They have come out with a wireless charging one. I have the iOttie Easy One Touch for my Note 8. Since it fits a wide variety of phones, I won't have to get another for my Note 10+.
I have never found one that worked with a vent. Not with the heavier Notes. Tried them (can't remember brands, been a while) with both my Note 4 and my Note 8. CD slot ones tend to work their way loose far too easily.
https://www.iottie.com/Product/List?Category=SmartphoneMount
I agree with the iottie! I'm not sure of the model # but it can attach to the windshield or mount anywhere with the included disc that you first place on the dashboard, etc and then it mounts onto the disc. I've never had it fall down or any issues with it. And it does fast wireless charging, and can fit a wide array of phones. I use it with my work issued Samsung Note 9 and my Samsung S10 +. It's also very adjustable, in/out, up/down. Turn it sideways and it'll charge while you're watching a video. In my opinion, it's worth every penny.
