Best samsung galaxy s4 case?
Raptor, have you ever used the OB defender? I am a believer in its ruggedness after watching some major drop tests. Some dude even threw the phone off the second floor off his house three times using the S4 commuter case and it took the third time to destroy it, even after using the commuter for four other drop tests. I would think the defender would be suitably rugged. :-) more so than the commuter, anyways.
I am considering the otterbox commuter because that is the case I had on my iphone 3gs...is that a good choice?
I have the otterbox commuter. Great case but the only complaint I have is I dont like how the home button feels on the side when being used. Kinda have to use extra pressure.
I'm using the Spigen hybrid neo in red. I think it's the best case I've owned.
Sent from my SAMSUNG-SGH-I337 using Tapatalk 2
I usually go necked so the OB commuter is huge jump in protection for me. The employee that broke four phones this year gets the defender.
Well lately I've been a fan of clear cases...so I am really liking the simple clear version of the Rocketfish Mobile Soft Case.
I am trying to find an S4 case that has a built in battery and also can clip onto my belt. I've found cases with built-in batteries (Maxboost, Exogear), but not the combination that includes a belt clip. Does anyone know if there is a product matching my requirement?
OB commuter...don't mind the bulk for the protection it gives....would like to try slim armor though....
OB Defender on my GS4.
Posted via My Samsung Galaxy S4 Handheld Device
Waiting for my casefanatic kommander to come in. Anyone have this?
Sent from my Samsung Galaxy S4
I use the Samsung protective case plus. Works great.
Sent from my SCH-I545
I think a black Sgs4 would look awesome with the Hornet otterbox defender.. Pretty swell.. :thumbup:
Courtesy of My LT3VO :D
Returned Neo-Hybrid...charger (other than the Samsung) did not fit.
Got Otterbox commuter today...great! Not worried if I drop it now ;)
the platinum series case that best buy sells is a pretty good case. Provides protection without adding too much bulk. Only thing is once you put the case on its hard to get off, but at least you know its secure.
I dropped my phone with Otterbox Defender and once with Spigen Neo Hybrid. Both saved my phone.
smithjonathan22
