Best SD card for using as internal storage Moto E 2015 Android 6.0 Marshmallow?
cesarri
I have a Moto E 2015 that has Android 6.0 Marshmallow and I want to use the SD card as internal storage. What is the best SD card to use? In terms of speed, capacity, etc. Thanks a lot! :) Greetings, César
I' using a 128GB Sandisk card. I don't there is more capacity yet, I just store media files on it so speed isn't a problem.
Any phone that can support a 128GB card should be able to support a 200GB card. There are no larger ones yet, but the interface supports up to 2TB.
I agree with using SanDisk cards - they're just superior.
(I wouldn't use a card as internal storage - that causes it to go bad a lot faster. Set it as portable storage. If you must have more apps on the phone, get a phone with more internal storage. eMMC is designed to be written to constantly, SD isn't.))
Ok, but, it's not actually my phone, I'm giving it away and I want to know that. Do you know or not? Thanks
cinemacritic
