Best Tempered Glass Screen Protector for Galaxy S6?
I've just bright a cheap one from eBay. I've used a cheap one for my s4 and had no issues. Seems to resist scratch and feels like glass too.
Posted via Android Central App using galaxy s4
Yes I do, I'm thinking the quality of Verizon's screen protector is just poor. Probably will try to return it and get a Zagg.
Doubtful, I keep my Verizon protector in an empty pocket and not one scratch almost 3 months later. Not even a microscratch yet but those can and will happen. Verizon is 9H rated just as Zagg so you may have had a bad protector to be honest.
I do prefer Zagg Glass though and its the option I'd choose since its available.
Has anyone tried zaggs HDX? I read that they cover more area, show less fingerprints and are thinner\more flexible?
Blue light can hurt your eyes, so you can try one anti blue light screen protector, which is better and expensive:)
Got the Zagg glass screen protector installed at the verizon store but the salesperson told me up front their current batch had an issue with bubbles and that he'd replace mine once they got the new batch in. I have a bubble on the top corner.
Right. I doubt they exchange it because of the scratch, although I am very careful so not sure how it happened.
I got the iCarez on Amazon. The edge around the screen that it doesn't cover is fine by me, better than a 'halo' effect. Plus the case I got(Spigen Neo Hybrid) has a lip, so that part of the screen won't even get touched if I drop it.
Anybody tried the tech 21 screen protector? T3 magazine have it the thumbs up, but it's pricey (£20)
francomattia
