Best Tempered Glass Screen Protectors?
Okay, I am on my second one. The AnoKe one simply was too big and would not apply to the screen since it touched the metal edge. The second one I got has an air bubble edge issue around 3/4's of the screen. It actually fit which is a good thing, but seems to be curved away from the glass. It was from Supershieldz.
So far I'm not happy with either one, although at least the Supershieldz one fit! In addition it does not appear to cause touch screen problems.
By the way, you asked if thicker was better. In my experience with Tempered Glass Screen Protectors thinner is always better. Since they can effect the touch capability of the screen and finger if they are too thick.
What do you mean - it curved away from the screen?
I've seen that there is a glass protector with a bezel around the edge - do you know anything about that? Like, the edge is curved (probably downward)...?
The adhesive sticks in the middle and goes clear, but near the edge it seems to pull away from the watch face. So basically either my watch face isn't flat (probably not the case) or the screen protector is higher at the edges. So using simple symbols it should edge on shaped like this |, however it is actually shaped like this ). So yeah not happy since you can see the air gap around 3/4's of the edge...
I have no air bubbles or lint. I also apply all screen protectors in the bathroom with the door shut and after the hot water has steamed the room up. Wasn't a problem centering either. It fits right up to the edge, in fact I can barely tell there is even a screen protector on.
Again, which one did you get, @murof?
Don't you find that the steam from the room gets moisture underneath the protector?
Steam helps to catch all of the dust particles in the air aiding in keeping bubbles and raised places on screen protectors.
The key thing seems to be finding a tempered glass protector that isn't warped and is the right size. My latest from vonoto (yes this is my third attempt) is warped, but is the right size. They were extremely responsive in processing a refund and once they refunded I turned around and ordered another one from them, hoping the warping was not a problem with all of their protectors. It should be here this weekend. Meanwhile the warped one has an air bubble between 12 and 2 on my watch that will not go away (and shifts when I lift and re-position the screen protector.
The problem with this one isn't dust underneath... I have had an amazing amount of trouble finding a protector for this device when most of the time I buy one, apply it and go on about my business. I've applied over 10 of these things on various devices and know what I'm doing and typically do not have trouble...
The saga unfortunately continues...
Can you please keep us updated on the next one your receive?
Is everyone else having the same troubles?
I can't believe you've had your urbane for almost 3 weeks now and still haven't used it lol. I ripped into mine the second I got it out of the mailbox
Yeah, well, I'm waiting to have the right screen protector, and I wanna install a metal band right from the start. (Plus, I am going away in a week and I won't have service.)
smith-jhone
