Best wireless (Qi) charger for Nexus 7 (2013)?
geekynerd00
18
The title says it all. I'm noticing my N7s charge port is getting a bit lose, so I figured I should I have a backup way to charge just in case. Google's is out of the question at $50 (!!!!)
Sent from my Nexus 7 using Tapatalk
I bought Zens for my Nexus 5. However, considering it's also near $50 in the shop android store it might also be out of the question for you. If you consider it, it's really a good charger. I think the Nexus 5 Qi charger is less, so might want to consider that as well.
dewiit
