Beta 7.1.2 (NPG05F) is Out
Bluetooth stack appears to have been fixed. I can now connect via Bluetooth to my 2011 Chevy when I could not on 7.1.1
Glad that's the case for you. :)
I was having my usual bout of stuttering music via Bluetooth on 7.1.2. Only a factory reset fixed it (for now). Google Support told me today that they are aware of continuing Bluetooth issues; it's not fixed yet.
Another bug found (???)
I connect Nexus 6P with my Windows 10 via USB cable.
Charging works but Windows IS NOT ABLE TO ACCESS TO THE STORAGE OF NEXUS 6P !!!
Of course this is extremely annoying.
Tested with both my "TWIN" Nexusa 6P with beta NPG05F Android stock 7.1.2.
I correct myself: CHARGING via USB SEEMS TO WORK but DOES NOT CHARGE !!!
No problems with the cable since the same cable connected to the SOCKET ON THE WALL works, i.e. charges Nexus 6P,
Today I installed NPG47I. Same problem. No charging via USB cable connected to any USB port of my notebook and NO ACCESS to the storage of Nexus 6P from Windows.
CAN ANYBODY OF YOU TRY THE SAME , TRIVIAL , EXPERIMENT and report to me?
THANKS
THANKS
My phone is charging off computer USB, but cannot access phone's storage.
Nexus 6P
7.1.2
NPG47I
Nexus 6P
7.1.2
NPG47I
Have you tried plugging your phone into your pc then using the pull down menu, changing the usb input from charging to file transfer?
Thanks for the help! I didn't notice that before. I thought it was an issue/setting on the Windows end when it asked me what I wanted to do when it connected. Problem solved, thanks!
is it recommended to manually flash the stable 7.1.2 or wait for an ota out of beta?
mmn112233445566111
