What uses most of my battery is the display.
I can't turn everything off, or why even have the phone? These phones are meant for multi tasking and heavy use..
Lucky for you! Mine seems to be worse than ever from the update! I unplugged it when I got up from work, put the screen on once to check the time, placed one 2 min call to my husband and 1.5 hours later it was down to 75% already. If I'm actively using it, it drops one percent per minute. Ridiculous. Anybody else having any battery draining issues?
The charging is slower than slow. With my display on and it charging, it took five hours to charge like 45 percent. I said to hell with that. I put in my spare charged battery and put the one from the phone in the charger. Geez, really ... five hours for 45 percent!? My battery never took that long to charge.
Love my phone ... don't love the battery! And I will give the Maxx credit for setting a new standard in battery life. Let's hope HTC catches on in the future!
Sounds like for some their phone is not going into deep sleep mode, thus causing increased battery drain overall, even when charging (thus causing the longer charging times). According to a thread over at XDA (ICS - Deep Sleep issue... Related to Charging? - xda-developers), the problem can occur with ICS when a USB charging source is connected to the phone that may then trigger a process that prevents the phone from going into a deep sleep. A few workarounds to ensure that process isn't preventing the phone from going into deep sleep:
- Reboot the phone after connecting or disconnecting a USB charging source
- Charge the phone with it powered off, disconnect USB cable, then turn on
- Use an external battery charger and swap out for a fresh battery (avoids the USB charging source)
