bigger fonts
zoa
Active member
Jan 11, 2011
43
Is there a way to increase fonts, bigger than the biggest setting in the phones settings?
I already have it set to 20 Biggest.
Is there a app?
Email, text, and even tapatalk?
Try going to Menu, Settings, Accessibility. There are options for vision impaired users like Zoom Mode, Read Back, and Talk Back.
I need just a darker font or just a little bit bigger. The zoom mode is a little too much.
I use reading glasses, but don't always have them with me.
Here's how you can make the font a little bit bigger:
Step 1: Hold the Droid X in your hand.
Step 2: Move that hand closer to your face.
There you go! Glad I could help. :D
There you go again. Cutting corners.
Which hand?:confused:
Unfortunately, as you will eventually find out, as one ages, the reading material needs to be moved farther away from the eyes, not closer, to be seen. ;)
Root your device and then you can change the font. Some custom roms have the ability to change the system font built in, otherwise, you can use an app like Font Changer to change the font.
Some of the fonts can be found in bold as well.
I'm in the same boat, and holding it closer does not work as they said..
How do you "root" your device"?
Thanks in advance --
- Luclarie
Godfrey
