Bixby remapping?
One click, Google assistant, two clicks Google task, hold click messenger.. one click and a hold YT music
But I'm using bxactions
No problem, wish could help more .
Now that we can remap Bixby button I still have the accidental hit issue. Can it be programmed so one push does absolutely nothing? Right now I have it set for clock but I really prefer it does nothing.
How about this... can it do volume down? Most often that is what I am reaching for when I hit it.
Also although unrelated what is so special about the infinity wallpaper? It doesn't DO anything does it?
Not that I know of , I think probably bxremaper might have more options
You can use bxaction to map single click to change sound profile. That down not require pro version or any remapping using PC.
Forgot to answer the wallpaper just the animations it makes if you like that
I like animations but with the stock infinity wallpaper I never saw it move on homescreen nor lockscreen?
Only when you about to go into the phone it shows a animation unless you have it off
Due to face unlock I probably never see it. It is only there for a flash. I would prefer it to move on homescreen. At least I get it now. Thanks.
I'm looking for an app that just mutes at the touch of Bixby without additional apps. That would amount to doing nothing. I don't want to be redirected out of an app I am in when I accidentally hit bixby button.
Can it be programmed to a activate a widget instead of an app? BXactions and others no longer work with activating in a pc which I won't do.
On the Bixby settings menu I have the "Double press to open Bixby"selected and under that did not turn on the "Use single press". Now when I single press nothing happens and Bixby opens with a double press.
dnszola
