Bluetooth = Battery Killer?
this_is_nascar
780
I've been using BT on my Droid Turbo running LP for quite a long time, without issues.
I just got a Moto Z Play Droid running MM and BT is always the 2nd highest battery drain, even if my BT device is not powered on/or connected.
Is this a MM shortcoming or something else?
I have Bluetooth, wifi, GPS and everything else turn on and still get fantastic battery life on the Z Play. I wouldn't worry about it!
I have the exact same issue as you, except with wifi instead of bluetooth. Like TJH132 said though, I wouldn't worry about it since the Z Play gets insane battery life regardless. I still get a minimum of 1.5 days (2 days if I run it completely down) and 8-10 hours SOT with heavy use.
Emmhodes
