Bluetooth headset problems?
JayH#AC
3
Anyone else having issues with their bluetooth headset? My Pro PlanTronics paired fine, connects fine. The phone even shows that it is connected to the headsets audio, but when I make a call, the audio is still at the phone. I can't even switch it to the headset using the interface. I have to turn off the headset, then turn it back on while the call is ongoing to get the audio to the headset.
I paired my Jawbone yesterday and tried it once. It worked fine, but i havent really put much time into it. Try re-pairing if you havent already. Also some headset have advanced modes? maybe that would help
My headset paired and connected without any issue but the volume will not get loud at all. It's almost impossible to hear the other person talking but they say they hear me fine. I really need to get this resolved.
Have you turned up your volume on the headset itself, as well as using the volume rocker while in a call to set the phone's bluetooth volume higher? They seem to work independently.
I've had no issues pairing to my car (mazda). I have had so many issues with bluetooth, it seems like the only way to fix things are to constantly unpair and repair. That is my own experience though. I would definitely try resetting the phone and repairing before doing anything else.
BrüZZi
