Bluetooth keeps disconnecting device after 4.2.2 OTA
Thanks bro.
your suggestion did work for me. I just unselected the two options in my power saver mode...
1. CPU power saving
2. Turn off haptic feedback...
and now I am able to talk on my bluetooth headset beyond 2 mins. I just now talked for more than 3 mins and it was alright for me...
It must be noted that my power saver as a whole is still ON and two of its options
1. Screen power saving and
2. Background colour
is still checked in for the power saving mode...
I hope it will help others also.
I used to lose bluetooth connection during calls. Discovered that wifi calling apps such as Viber or Hangouts Dialier periodically resets the phone mode in teh background to default (= handset earphone) every few minutes. When I removed these apps, my bluetooth problems went away. The only wifi calling app I have found that did not aggressively reset the phone mode to default is WePhone.
thankyou for this simple yet very effective solution to my blue tooth dilemma. I was in the process of buying a new phone because I couldn't figure it out. all I did was turn off the power save option and all was fixed.
ecomranx20
