Bluetooth mouse connection problem
keelotan
When I connect my Logitech mx anywhere mouse to my LG-V500 tab using bluetooth it works ok, BUT when I need to type the keyboard does not appear. As soon as I turn off the bluetooth the keyboard reappears but of course I cannot use my mouse. What am I doing wrong?
It sounds as if the phone switches to Bluetooth mouse AND keyboard - but there's no Bluetooth keyboard there. Check Settings to see which keyboard is selected (and change it to another one, then back, just to be sure). It could also just be a peculiarity of the particular phone. (My Note 3 can use a BT mouse with no keyboard interaction - both the external mouse and the internal keyboard work at the same time.)
Thanks for the reply. The LG Tab keyboard selection has the LG keyboard slected as default and greyed out with no other choice.
KidColoringPage
