Bluetooth Problem
NiffiIsenguard
316
Litteraly a stupid question but I can't find an answer
How many BT devices can I be connected to? I was trying to connect to my UEBOOM and had my S2 Gear on.
Greetings! Welcome to the forums!
You can connect some things at the same time, depending on what they are. You can't connect two speakers/headphones as the device doesn't know which one to send the audio to. But you stream music to your car audio and a call comes through, it should work. Some headphones allow you to"share"also.
Anyway, there are myriad variations so just give it a go and see..you can't do any harm...
My initial answer would be yes you can. Just try pair both devices and see if it works. Bluetooth 4.1 definitely has the capability.
However, some devices don't have the hardware capability to do so like headphones it can only connect 1 device at a time. The comment above me made a good example using headphones and music.
A droid a day keeps the Apple away
Okay thanks. I'll see if it.was maybe my UEBOOM that's having the issue.
Was hoping to have it so I could just turn the dial to change the song when I'm cooking
Bride96
