Bluetooth Problems
ptf
103
Hi all,
If I disconnect from my DX's Bluetooth, I have to turn the Bluetooth off and then back on to connect to something else. Anyone else have this issue/know a workaround?
Sent from my GT-P7510 using Tapatalk
Hi all,
Have you tried entering Settings / Wireless Networks / Bluetooth Settings and click the item you want to connect and select Connect, also did you turn off the other device?
I don't have the option to connect on my DX, even when I long-press the device. I always connect on my Galaxy Tab 10.1.
Auto-corrected by my Galaxy Tab 10.1 using Tapatalk. Please exclaimed my terrors (This was auto-corrected from: Please excuse my errors).
If the device says paired but not connected on the dx you can press to reconnect. Doesn't always work for me on GB. I may have to reboot.
Sent from my DROIDX
It says paired but not connected, yet I can never connect to the Tab from my phone.
The device will not allow being constantly connected to another device, if you select a file to transfer from one device to other it will connect to transfer file and then disconnect, I haven't seen two device remain connected all the time. A bluetooth of handsfree will stay connected but not another device,
My phone is paired with my laptops bluetooth and the only time it connects is when I am transferring data.
They stay connected fine... It's just that after I disconnect, I have to cycle the Bluetooth to connect the phone to anything else.
Maybe I'm special?
Khalequzzaman
